Introducing a new online tool for power quality simulations
By Andrew Zistler | December 17, 2015
ShaffnerSchaffner EMC introduces PQS, a Power Quality Simulation tool which allows planners, consultants and application engineers to accurately model and simulate low voltage 3-phase network topologies. This powerful online tool is easy to use, with drag and drop convenience, drop-down menu-driven functionality, and fill-in-the-blanks simplicity. It allows the simulation of power, current and voltage at all network modes, and supports the proper selection of harmonic mitigation technologies. Schaffner PQS verifies compliance with selected power quality standards, and it provides comfortable reporting features. It is ideal for application engineers, planners, consultants, plant managers, and others responsible for the power quality within all industries.
This robust tool allows users to select medium and low-voltage transformer parameters (voltage, power, short circuit current, and impedance), specify cable (length, diameter, and material), and then add loads and harmonic filters. With drag and drop convenience, users can select common loads such as furnaces, motors, resistive loads, DC motors/battery chargers, and Variable Frequency Drives. When these elements are added to the circuit, PQS prompts the user to fill in applicable parameters for each component.
If the system design will not support the load, for example, a message will be generated suggesting that a larger transformer may be required, and then stay illuminated until the power supply issue is rectified. PQS supports all Schaffner harmonic mitigation technologies, including active and passive harmonic filtering, and chokes, as well as power factor correction.
Harmonics can play havoc on the electrical power network, causing, tripped circuit breakers, blown fuses, overheating of motors and transformers, insulation break-down and reduced service life of equipment. Issues range from a “simple” nuisance to catastrophic loss. Further, production downtime, repair cost and revenue shortfall, may result in reduced company profits. Harmonic filtering helps to eliminate many of these concerns, enhance efficiency and improve overall plant performance.
Schaffner EMC
schaffner.com
Power Electronic Tips
Filed Under: Software • simulation, Power Electronic Tips
Tagged With: schaffneremc
