    • Subscribe!
Introducing Graphic HMIs from Maple Systems
By Stacy Combest | August 2, 2013
Maple Systems HMI Models are certified for harsh environments, including UL listing, RoHS, and CE, and are backed by our comprehensive two year warranty. EZWare compatibility across all products makes migrating projects and upgrading existing hardware quick and easy.
HMI5000HMI5000 Line – Touchscreen Operator Interfaces to meet your every need
The HMI5000 Line of Touchscreen Operator Interfaces comes in 12 different models with a wide variety of features to meet every automation need. Rugged, corrosion-resistant components, high-quality LED-Backlit touchscreen displays from 4.3″- 15″, and industrial-grade construction ensure optimal performance in the most demanding automation environments.
Support for over 100 PLCs from a variety of manufacturers means our products will work in virtually any SCADA deployment. External ports extend the capabilities of the HMI for connecting a mouse/keyboard, audio, or flash drive for data-logging. In addition, The EZware configuration software simplifies the task of creating custom screens for the operator interface to fit each application. From the robust HMI5000P, all the way to the ultra-slim HMI5000L, you can rest assured that we have the right human machine interface for your project – at the right price. HMI Models are CE, cULus and RoHS certified.
HMI5000PHMI5000P Series – Top-tier Human Machine Interface with enhanced features
The HMI5000P, our top-of-the-line Graphic Operator Interface, features next-generation CPUs, ample memory, a crisp high resolution display. These touchscreen interfaces come in three sizes (7″, 12″, and 15″) and are encased in anti-corrosive aluminum enclosures for added strength and durability. The HMI5000P can connect to a myriad of other devices and PLCs through built-in USB, serial and ethernet ports. In addition, the 12″ HMI5121P and 15″ HMI5150P come with two video inputs, and the 7″ HMI5070P supports an extended operating temperature range, making the HMI5000P Series your ultimate HMI solution.
HMI5000N_THMI5000N/T/NH/TH – Optional Ethernet for flexibility and compatibility
Available in 4.3″, 7″ and 10″ display sizes, the HMI5000N/T/TH/NH Series is a family of powerful mid-range HMIs with an optional Ethernet port in every display size. In addition to connecting to PLCs that support Ethernet, this feature lets you monitor your control system from a remote location or update the HMI. Multiple serial ports on each model allow connection to many PLCs.
HMI5000LHMI5000L Series – A sleek new look in an ultra-slim form factor
At 1.3″ thin [1.6″ on the 10″ model], this slim-line Machine Interface packs quite a punch and is optimal for environments with limited enclosure space. The HMI5000L Series comes in 7″ [HMI5070L] and 10″ [HMI5100L] display sizes with a grey, impact-resistant enclosure that offers a contemporary look.
Maple Systems
www.maplesystems.com
Filed Under: HMIs • operator interfaces • monitors
Tagged With: maplesystems
Bluetooth-enabled digital readout
ADISRA InsightView-IV_main_dash2
ADISRA InsightView delivers advanced equipment analytics
Watlow’s POWERSAFE medium voltage thermal system
Portfolio
Packaging upgrades increase brewery’s efficiency
    • Subscribe!
