When space is tight and display performance is critical, PORON SlimGrip foam is an ideal fit. SlimGrip foam is Rogers’ softest material yet. With a starting thickness of 0.5mm and the ability to squeeze into gaps less than 0.05mm, no space will go unfilled.
In fact, SlimGrip foam requires one-third the force to achieve 0.05mm thickness compared to competitive materials, all while maintaining excellent rebound properties. That means less work is required for even greater performance. Additionally, this material is 50% more effective at dust sealing than competitive materials, further protecting the integrity of displays.
SlimGrip foam is provided on a 0.05mm release PET film. When the PET is removed, a tacky surface is exposed, leaving behind no incompressible layers. The tacky surface may assist in the temporary placement of gaskets, further easing production. With incredible compressibility, excellent resistance to compression set, and reliable dust sealing performance, SlimGrip foam is a valuable addition to the PORON family of materials.
More information on PORON Urethanes.
Rogers Corporation
www.rogerscorp.com
