IO-Link Smart Field I/O System from AutomationDirect
By Mike Santora | May 27, 2022
stride-murrelektronik-io-link-5x7AutomationDirect has added STRIDE & Murrelektronik IO-Link master modules and hubs to their existing field I/O product line.
IO-Link is a powerful field I/O protocol capable of handling traditional field I/O signals along with diagnostic data from intelligent field devices, including device health, configured parameters, and performance.
IO-Link master modules are the interface between field devices and higher-level controllers/information systems, and they also control data traffic between the connected devices. Two IO-Link master modules are now available that convert IO-Link signals to/from EtherNet/IP, OPC UA, and MQTT.
The STRIDE IO-Link master will convert IO-Link data to EtherNet/IP messages for better insight into system performance using a well-established fieldbus protocol
The Murrelektronik premium master module provides the same advantages as the lower-cost STRIDE version, with the added capabilities of OPC and MQTT
IO-Link hubs provide up to 16 multifunctional DIO channels that allow several standard sensors and actuators to connect to an IO-Link master using a single cable. IO-Link hubs offer an economical solution for a highly decentralized installation.
A variety of IO-Link capable photoelectric and proximity sensors are available that provide signal data, as well as internal diagnostics, to keep operators aware of sensor faults and performance issues.
AutomationDirect
www.automationdirect.com/io-link
Filed Under: I/O modules
Tagged With: automationdirect
