IP67 Rated Panel Sealed Rocker Switches
By Patrick Curran | March 4, 2011
NKK Switches announced the availability of the JWMW and JWLW series, the industry’s first molded, IP67 rated panel sealed rocker switches with TV ratings. These snap-in mounted devices are specifically designed to handle large inrush currents.
NKK-JWMW-and-JWLW-series-switch
The smaller JWMW series features a panel cut out of 25mm X 15.4mm and is certified for TV-5. It has an electrical capacity of 10A @ 125/250V AC resistive and 10A @ 30 V DC. Larger JWLW devices have a panel cut out of 30.7mm X 20.5mm and are TV-8 rated with an electrical capacity of 16A @ 125/250V AC and 5A @ 72V DC.
JWLW devices are particularly well suited as power distribution switches for telecommunications applications. The series’ capabilities exceed a 160A inrush load. Major telecommunications companies such as Nortel, Alcatel, Motorola and Ericsson have designed applications using these switches.
These devices have an exterior seal covering the flange that is an integral part of the switch. They are rated to IP67 of IEC60529 standard, which is similar to NEMA 4 and 6. An optional watertight boot is also available. Featuring UL, CSA and VDE approvals, JWMW and JWLW switches also carry a flammability rating of UL94V-0.
All JW rocker switches are constructed for dust resistance with an interior polyphenylene sulfide seal between the actuator and contact area. These devices also feature prominent external insulating barriers which increase the insulation resistance and dielectric strength.
JW housings and cases are polyamide, a heat resistant resin meeting UL’s 94V-0 standards. The solder lug/quick connect terminals are molded in and epoxy sealed to lock out flux, dust and other contaminants. The terminals are also specially designed to break light contact welds and can be used with connectors.
Design engineers can configure SPST, SPDT, DPST or DPDT circuits. All single throw models can be ordered with the international inscriptions for ON and OFF. These can be specified in vertical or horizontal orientation to accommodate any panel placement needs.
JW devices include an integral rocker cap available in color options of black, gray, ivory or red. Housings can be specified in black, gray or ivory.
NKK
www.nkkswitches.com
Filed Under: Electronics • electrical, Switches
molex-premo-flex
