IP69K Cooling Fans, Only from NMB
By Frank Tobe | November 7, 2016
NMB Technologies Corporation, a Minebea Group Company, introduces the only series of IP69K cooling fans available in the market today. No other cooling fan manufacturer can offer IP69K rated cooling fans, the highest proven protection available against closed range, high temperature, and high pressure spray-downs. These IP69K fans are designed to be protected from environmental factors, and are the desired component for extreme environment applications.
This new series of IP69K fans is available in 12VDC, 24VDC and 48VDC, with air flow from 8 to 346 CFM. Sizes available include 40mm, 60mm, 92mm, 120mm, 150mm and 175mm. Designed with a new, high reliability in high temperature metal casing, plastic magnet, and if desired, stainless NMB bearings with ceramic balls, and offer a life expectancy of 100,000 hours in 25°C.
fan-ip69k-familyApplications for the IP69K Cooling Fan Series from NMB include:
  • Indoor/Outdoor Harsh Environments
  • Food processing
  • Refrigeration
  • LED Lighting System Cooling
  • Inverters
  • Telecom
  • Horticulture
These NMB IP69K fans are currently available for direct OEM sales, and at our distribution partners, Digi-Key , Arrow and Newark.
NMB
www.nmbtc.com
Filed Under: Fans, Lights • signal lamps • indicators, MOTION CONTROL
Tagged With: nmbtc
