    • Subscribe!
Ironwood Electronics Presents 27 GHz Bandwidth Open Top Socket for BGA121
By Ironwood Electronics | February 1, 2017
Ironwood Electronics recently introduced a new high-performance BGA socket for 1mm pitch, 121 pin BGA IC’s. The SG-BGA-6457 socket is designed for IC size — 12x12mm package size and operates at bandwidths up to 27 GHz with less than 1dB of insertion loss. The contact resistance is typically 20 milliohms per pin.
Works with devices such as 121BGA, 12mm square package with 11×11 array and 1mm pitch.
Key Features
  • Socket connects all pins with 27 GHz bandwidth on all connections
  • Socket is mounted on the target PCB with no soldering
  • Constructed with open-top lid for access to the center of IC package
  • Comes with ball guide for the precise alignment of BGA balls to PCB pads
  • Constructed with high-performance and low inductance elastomer contactor
  • Temperature range is -35 C to +100 C
  • Pin self-inductance is 0.15 nH and mutual inductance of 0.025 nH
  • Capacitance to ground is 0.01 pF
  • Current capacity is 2 amps per pin
EXE014 - Image 1
    • Subscribe!
