Isolated Digital I/O for Embedded Systems
By Design World Staff | November 13, 2009
The PCM-3730I is a 32 channel isolated digital I/O PCI-104 module. It supports high-voltage isolation (2,500 Vdc) on each input/output channel and resists noise interference. Additionally, 32-channel isolation ensures accurate input/output data values while simultaneously allowing the system to access more data.
With a wide input voltage range (5~30 Vdc), the module is suitable for any application with 12 or 24 Vdc input voltage. Different modules can be stacked together in a small system such as an embedded computing platform. The module supports Windows 2000, Windows XP, and WinCE 5.0/6.0.
Advantech Corporation, Industrial Automation Group
www.advantech.com/ea
Filed Under: I/O modules, Networks • connectivity • fieldbuses
MTConnect Institute releases Version 2.0 of the MTConnect Standard
OPC UA
Everything is moving – OPC UA Companion Specification “Global Positioning”
Single common conformance test plan to be available for the IEC/IEEE 60802 TSN profile for industrial automation
Ethernet/IP Network specification complete for Ethernet-Apl physical layer for process automation
