A highly innovative range of pneumatic cylinders from Norgren, is bringing substantial operational and commercial benefits to a major manufacturer of surface finishing equipment and its customers.
US-based Corrotec Inc. designs and manufactures custom-build process systems for the surface finishing industry, including zinc, chrome, copper, POP, nickel plating and anodising. The company builds system modules at its facility in Springfield, Ohio, and then assembles and installs them at its customers’ locations. The systems range in size from 12 to 120 metres in length and width, depending on individual customer requirements.
The logical next step in the I/O block was to modularise the pneumatics system. Corrotec uses a lot of pneumatic valves for its diaphragm pumps and also to lift and lower rotary tables and open and close gates. The machine builder considers pneumatics as the best option because of their chemical resistance.
The modularisation process has now for the first time moved into the area of pneumatics, enabling Corrotec to do away with long runs of tubing and make significant savings on installation time.
This is being achieved through the use of the IVAC (integrated valve and actuator control) range from Norgren. An integrated unit which delivers Engineering Advantage by combining the valve, flow controls, cushioning and sensors in a single actuator package, IVAC is a weight and space optimised actuator, suitable for a range of bore sizes from 32mm to 100mm, featuring integrated valve and magnetically operated switches for complete actuator control.
It was while Corrotec was designing a dye penetrant inspection system for the aviation industry that the company was first introduced to IVAC. The inspection system uses an overhead conveyor to move aircraft parts through different steps of an inspection. At various points throughout the process, doors open to allow the parts into various equipment and operator areas such as dryers or operator stations and then close behind them. Pneumatic cylinders are used to actuate the doors.
In this application, using IVAC enabled Corrotec to connect each cylinder with just one air line from a distribution header and one cable from an I/O block – saving considerably on installation time when compared with installing a traditional valve island and all the tubing on site.
Given the scale of the systems Corrotec install, the company says that shortening the installation time by a day or two (which IVAC allows them to do) means real value for their customers who can use their system sooner, meaning there is a direct payback on the machine in a short amount of time.
The other key advantage for Corrotec’s customer is maintenance. A single non-functioning door can shut down the whole machine. With a traditional system, it is unlikely to be immediately clear where the problem lies– it could be the cylinder, the seal or the valve.
The new system has 20 IVAC units on it with spares kept in the warehouse. If a door were to stop functioning, it would take just 30-40 seconds to remove the pins that hold the IVAC unit in place. This can then be replaced and the machine is back online almost immediately. The cylinder that has been removed can then be analysed for the problem.
Corrotec also chose the ‘cleanline’ version of IVAC – designed originally to meet the exacting hygiene and washdown requirements of the food and beverage sector – even though the system is not technically a wet area.
Norgren
www.norgren.com
Filed Under: Actuators, Cables + cable management, Pneumatic equipment + components, Pneumatic Tips
