    • On the Floor
ix industrial Ethernet connector is a miniature replacement for RJ45 designs
By Mary Gannon | October 3, 2018
The RJ45 connector has been the standard Ethernet interface in IP20 environments for many years. However, as the demand for smaller devices and sensors increases, the RJ45’s size limits the potential for miniaturization. This is why HARTING developed the ix Industrial Ethernet connector, which is a smaller and more rugged connector than the standard RJ45. It also offers Cat. 6A performance for 1/10Gbit/s Ethernet at the control Level.
Harting ix industrial Ethernet connector HeroThe socket size of the ix Industrial is 70% smaller than the standard RJ45 which allows device manufacturers to use this technology in much smaller devices. For device integration, a small yet robust socket with five THR shielding contacts is available for maximum stability on the PCB. The ix Industrial features stable latching through the use of two metal hooks, and together with the new socket ensures an absolutely secure and vibration-proof connection from the cable to the circuit board — for a minimum 5,000 mating cycles.
In regards to device wiring, users can take advantage of flexible, thin system cables with a tight bending radius. The ix Industrial can be assembled with the mating face on both ends or mixed, i.e. with it and the RJ45 connector on opposite ends. This enables a gradual adaptation of individual elements in the control level without the need to directly revise all systems.
The HARTING ix Industrial interface is also standardized in accordance with IEC/PAS 61076-3-124.
HARTING North America
www.harting.com
Filed Under: Ethernet — cables • hubs • switches, Connectors (electrical) • crimp technologies
Tagged With: harting
  • Agentic Requirements Engineering: Reduce Friction in Requirements Workflows
  • Five trends in automation for the second half of 2026
    • On the Floor
