NEW BERLIN, WI — J. W. Winco, Inc.announced it has expanded its line of tapped type ‚“NY-LEV‚“‚†Nylon Base Leveling Mounts.
A quality and economical solution to leveling and height adjustment needs, these American-made nylon base machinery mounts with tapped socket swivel 15 degrees in all directions. Due to the manner in which the tapped socket is manufactured from hex bar stock, the hex acts as a stop when moving the socket beyond is 15 degrees swivel point. Because of this, the socket will not separate from the nylon base.
Available in both steel and stainless steel with or without lag holes, the leveling mounts have a glass filled nylon plastic base and a non-skid elastomer rubber pad that resists many organic acids, most chemicals, alkalines, salt, water, and corrosion.
Filed Under: Fastening + joining • locks • latches • pins, Mechanical
