J. W. Winco, Inc. Offers Aluminum Crank Handles
By Design World Staff | November 11, 2007
(New Berlin, WI) – J. W. Winco, Inc. offers Aluminum Crank Handles with Recessed Locking Retractable Handle.
The body of the crank handle is aluminum with a black powder coated pebble finish and a light gray plastic hub cover.  The retractable handle is made of black phenolic plastic.  Special bores, squares, keyways, and set screw holes are available upon request.   This crank handle is generally used in applications requiring that the hand piece must not protrude when in use.  In the operating position, the hand piece is firmly locked, and by pulling in the axial direction out of its locating cone, it can be folded back into place.
www.jwwinco.com
: Design World :
Filed Under: Fastening + joining • locks • latches • pins
Covered compression latch enhances safety and reduces maintenance errors
Omron D41L hygienic guard locking switch is a tamper-proof solution for ensuring access control and workplace safety
Omron D41G guard lock and handle is an easy-to-wire and intuitive solution for safeguarding machine tools and robotic cells
Omron D41D high-coded non-contact door switch for safeguarding machine tools and robotic cells
