J.W. Winco Latching Toggle Clamps Provide High Retaining Force
By Editor | October 22, 2012
J.W. Winco, Inc. announced it now offers GN 852.1 Latch-Type Toggle Clamps with Locking Mechanism, in metric sizes.
These RoHS compliant Latch Clamps are used when very high retaining forces are required. They also feature a locking mechanism that prevents the inadvertent or vibration-induced opening of the clamp. Another benefit of this clamp is the ability to operate it with one hand.
GN852_1-with-label-2
The base, clamping lever and catch are forged, chemically blackened steel. Bearing pins are hardened and ground steel. All moving parts are lubricated with specialgrease. The handle sleeve is oil-resistant red solid molded plastic. Holding force (Fh) of this clamp is 15,000 newtons [N].
J.W. Winco
www.jwwinco.com
Filed Under: Clamps, Fastening + joining • locks • latches • pins
Tagged With: jwwinco
Covered compression latch enhances safety and reduces maintenance errors
Omron D41L hygienic guard locking switch is a tamper-proof solution for ensuring access control and workplace safety
Omron D41G guard lock and handle is an easy-to-wire and intuitive solution for safeguarding machine tools and robotic cells
Omron D41D high-coded non-contact door switch for safeguarding machine tools and robotic cells
