J.W. Winco, Inc., a supplier of standard industrial machine components, announced it now offers GN 115.8 Zinc Die-Cast Hook-Type Latches Lockable.
These RoHS compliant hook-type latches with hook and latch bracket are mainly used for sliding doors and flaps. The locking action is in radial direction to the axis of rotation, resulting in a wide variety of different uses. Two keys are supplied with the unit, and the key can be removed in both end positions. The latches are supplied with the hook enclosed loose, while hook-type latches with other latch distances or other pivoting ratios are available upon request.
The latch housing is zinc die-cast, while the locating ring is zinc die-cast, chrome plated or with a black powder coated textured finish. The latch hardware is steel, zinc-plated, while the key is nickel silver with plastic hand piece and the T-handle grips are matte black nylon plastic.
J.W. Winco
www.jwwwinco.com
Filed Under: TECHNOLOGIES + PRODUCTS, Fastening + joining • locks • latches • pins, Flanges • supports • mounts • brackets
