J.W. Winco Stainless Steel Thrust Pads Clamp
By Stacy Combest | June 14, 2013
J.W. Winco, Inc. announced it now offers GN 631.5 Stainless Steel Thrust Pads, in metric sizes.
These RoHS-compliant thrust pads, when used with GN 632.5 grub screws, are a low cost solution for clamping operations or for load bearing purposes.  The resulting assembly leans to accommodate uneven surfaces. It is easy to press the ball point of the grub screw into the thrust pad by hand.
Thrust-Pads
Thrust pads are made of stainless steel, European standard No. 1.4305 (American standard 303).  They have O-rings of FPM Rubber (Viton). Pad diameters range from 21 to 40 mm.
J.W. Winco
www.jwwinco.com
Filed Under: Bearings, Fastening + joining • locks • latches • pins
Tagged With: jwwinco
C2 lever latch offers auto-relock functionality and modern appearance
Covered compression latch enhances safety and reduces maintenance errors
Omron D41L hygienic guard locking switch is a tamper-proof solution for ensuring access control and workplace safety
Omron D41G guard lock and handle is an easy-to-wire and intuitive solution for safeguarding machine tools and robotic cells
