Jacketed Tube Connector Protects without Sleeves and Sealing Tape
By Stacy Combest | April 18, 2013
A companion piece to Swagelok jacketed tubing , the new Swagelok jacketed tube connector (JTC) is engineered to connect jacketed tubing systems, while protecting tubing from external degradation in corrosive environments. Designed to safeguard against environmental ingress in the chemical, petrochemical, oil, gas, and pulp industries, the JTC provides a leak-tight, Swagelok tube fitting connection between sections of single jacketed tubing, eliminating the need for sleeves and sealing tape.
Swagelok-Jacketed-Tube-Connector_Components
The jacketed tube connector’s patent-pending design combines proven tube fitting technology with an O-ring seal and an innovative, environmental jacket seal nut, providing a leak-tight seal on the stainless steel core of the jacketed tubing and a water-tight seal on the outer diameter (OD) of the jacketed tubing. The JTC design promotes streamlined installation and high performance, including:
  • Ease of assembly: Knurled jacket seal nut allows for easy, hand-tight assembly.
  • Repeated reassembly: Seal performance is maintained through repeated reassemblies of the connector.
  • Visual confirmation: Jacket seal nut covers vent O-ring when leak-tight assembly is achieved.
  • Vent port: Port prevents accidental pressurization of jacket cavity.
Swagelok-Jacketed-Tube-Connector_CrossSection
The connector is available in all standard tube fitting configurations and for use with 1/4, 3/8, and 1/2-inch jacketed tubing with up to 1/16 inch in nominal jacketed thickness. Operating temperature ranges from
-67 to 180° F (-55 to 82°C) and working pressures up to 5 100 psig (420 bar).
Swagelock
www.swagelok.com
Filed Under: Tubing components, Connectors (electrical) • crimp technologies, FLUID POWER
Tagged With: swagelock
