Jergens’ Hydraulic Vise Column
By Design World Staff | September 18, 2008
CLEVELAND, OHIO‚—Jergens, Inc. introduces their new Hydraulic Vise Column. Proprietary features such as the patented swivel coupling save operator time by eliminating the need to disconnect and reconnect the two hydraulic hoses as the column rotates. Each vise can be independently operated to quickly unload and load parts. The extremely compact rotary coupling does not interfere with tooling.
In-house testing of the Jergens Hydraulic Vise Column with swivel coupling achieved up to a 50 percent reduction in production time when compared to the manual version performing the same tooling operation. Hydraulic power provides a fast, repeatable action that ensures consistent clamping force, up to 4,700 lbs of clamping capacity, without the variability due to operator fatigue that can occur with manual vises. The hydraulics ensure consistent, repeatable clamping force. The operator simply opens the hydraulic valve to open the jaws to quickly unload and load parts.
With the fastest quick-change mechanism available, Jergens‚’ Hydraulic Vise Column comes with 4″ and 6″ jaw sizes and in three-sided or four-sided configurations. The stand-alone design can be retrofitted in the field.
All Jergens vises include machinable, reversible jaws; hardened and ground steel rails; flow-through base; and fully sealed lead screw assembly.
www.jergensinc.com
Filed Under: Hydraulic equipment + components, FLUID POWER
