J.W. Winco Introduces New Steel Leveling Feet
By Patrick Curran | April 8, 2011
J.W. Winco, Inc. announced it now offers series GN 440 Steel Leveling Feet in inch and metric sizes.
JW Winco Steel Leveling Feet
These RoHS compliant leveling feet are simple and economically priced. They have a base made of steel with a zinc-plated, blue passivated finish (stainless steel for type with rubber pad). The threaded stud is also zinc-plated, blue passivated steel, with a steel hex nut as a standard part of the assembly. A stainless steel assembly screw is mounted through the bottom of the base into the stud with loctite to secure it in place.
The feet may be ordered in three different versions: without pad; with a base cap of black, 73 shore elastomer (TPE) plastic; or with a non-skid pad of black Nitrile Butadiene rubber, 70±5 shore hardness. The static load rating of these feet is limited due to the acceptable load rating of the stud (tensile strength 500/mm2).
An all-stainless steel version, series GN 440.5, has also been newly introduced to the product line.
J.W. Winco
www.jwwinco.com
Filed Under: Assembly, Fastening + joining • locks • latches • pins
Covered compression latch enhances safety and reduces maintenance errors
Omron D41L hygienic guard locking switch is a tamper-proof solution for ensuring access control and workplace safety
Omron D41G guard lock and handle is an easy-to-wire and intuitive solution for safeguarding machine tools and robotic cells
Omron D41D high-coded non-contact door switch for safeguarding machine tools and robotic cells
