    • Subscribe!
J.W. Winco Offers Clamping Pads with Stems
By Dave Miyares | May 7, 2010
NEW BERLIN, WI — J.W. Winco, Inc. announced it now offers series GN 709.1 Clamping Pads with Threaded Stem.
JW-Winco-Clamping_Pad_with_Threaded_Stem
These RoHS-compliant, metric sized clamping pads have a body made of case hardened steel with a black phosphate finish. The ball is hardened steel with a plain finish. Two types are available: with smooth contact face, or with serrated contact face.
These clamping pads can be used as mobile supports or as a backstop for securing or clamping workpieces. The ball is limited to an angular movement of no more than 9°. A version with serrated tapped ball insert is available upon request.
J.W. Winco
www.jwwinco.com
Filed Under: Assembly, Fastening + joining • locks • latches • pins
C2 lever latch offers auto-relock functionality and modern appearance
Covered compression latch enhances safety and reduces maintenance errors
Omron D41L hygienic guard locking switch is a tamper-proof solution for ensuring access control and workplace safety
Omron D41G guard lock and handle is an easy-to-wire and intuitive solution for safeguarding machine tools and robotic cells
    • Subscribe!
