J.W. Winco Offers Conical Vibration Isolation Mounts
By Laura Carrabine | October 10, 2011
J.W. Winco, Inc. announced it now offers series GN 353 Vibration/Shock Absorption Mounts in metric sizes. Also known as shock absorbing mounts, vibration mounts, anti-vibration mounts, vibration bobbins or rubber bumpers, these RoHS compliant components are frequently used as end-stop bumpers, e.g., for conveyor trolleys.
Vibration absorption mounts absorb most of the accumulated kinetic energy on impact. They act as dampers and prevent damaging shock and rebound. They also act as sound dampers, and can be used as leveling feet. The parabolic shape generates progressive resilience characteristics: impact and shock effects are absorbed more gently.
JW-Winco-absorption-mount
Types with tapped hole or with threaded stud are offered. The mount body is of natural rubber (NR), vulcanized, 55 durometer (shore hardness +/-5°). Cover plate, and tapped inserts or threaded studs are molded-in zinc plated, blue passivated steel. Inch size tapped and stud versions are available upon request.
J.W. Winco
www.jwwinco.com
Filed Under: Assembly, Fastening + joining • locks • latches • pins, Shocks + vibration control • gas springs
Covered compression latch enhances safety and reduces maintenance errors
Omron D41L hygienic guard locking switch is a tamper-proof solution for ensuring access control and workplace safety
Omron D41G guard lock and handle is an easy-to-wire and intuitive solution for safeguarding machine tools and robotic cells
Omron D41D high-coded non-contact door switch for safeguarding machine tools and robotic cells
