JW Winco offers hygienic design adjustable hand levers
By Mike Santora | October 9, 2018
JW Winco-305-combi-1181px-Hygienic-Design-Adjustable-Hand-LeversJW Winco, Inc., A Ganter Company, a supplier of standard industrial machine components, is the first to offer and manufacture the new GN 305 Hygienic Design Adjustable Hand Levers.
The adjustable hand levers with solid stainless steel handles are intended for use in hygienic design applications, such as in the packaging, food processing, medical, and dairy industries. The sealed mounting surface enables fastening without dead spaces. The finish and impervious exterior surfaces prevent adherence of dirt and facilitate cleaning.
“These levers are ideal whenever parts have to be clamped in a confined space or in a particular lever position, as the insert is connected to the lever via serrations that can easily be disengaged,” said John M. Winkler, CEO, Office of the President at JW Winco. “When pulling up on the handle, the serration frees itself and can be re-located into any required position. Engagement is achieved by releasing the lever.”
The handle features a stainless steel precision casting, while the threaded insert is stainless steel AISI 304. The sealing ring/wiper is made of hydrogenated acrylonitrile butadiene rubber (H-NBR) that is FDA compliant and temperature resistant from -13 °F (-25 °C) to 302 °F (+150 °C).
JW Winco is a manufacturer/distributor of inch and metric standard parts. JW Winco offers an extensive selection of plastic, steel and stainless steel adjustable levers, cabinet U-handles, hinges and locking mechanisms, revolving and retractable handles, hand wheels, hand cranks, tube connection and conveyor components, construction tubing, shock absorption mounts, leveling mounts, hand knobs, spring, ball and indexing plungers, jig, fixture and fastening components, retaining magnet assemblies, toggle clamps, casters and wheels, universal joints, oil sight glasses, and metric tools for the industrial and commercial equipment industries.
JW Winco
www.jwwinco.com
Filed Under: ALL INDUSTRY NEWS • PROFILES • COMMENTARIES, Fastening + joining • locks • latches • pins
Tagged With: jwwinco
Covered compression latch enhances safety and reduces maintenance errors
Omron D41L hygienic guard locking switch is a tamper-proof solution for ensuring access control and workplace safety
Omron D41G guard lock and handle is an easy-to-wire and intuitive solution for safeguarding machine tools and robotic cells
Omron D41D high-coded non-contact door switch for safeguarding machine tools and robotic cells
