JW Winco offers latches with safety function
By Mike Santora | July 17, 2018
JW-Winco-Latches-with-Safety-FunctionJW Winco, Inc., A Ganter Company, a supplier of standard industrial machine components, has available GN 115.9 Latches with Safety Function, Zinc Die Casting, Operation with Key, not Lockable.
These latches, which are RoHS compliant, have a push-to-turn safety function. In the two end positions, the lock secures the spindle in place. The device can be turned 90° only when the operating element is pressed down, which releases the safety pin from the locked position. This feature protects the lock reliably from moving on its own or as the result of vibrations. The beveled edges on the lock make closing the door easy. The 15 different offsets allow the latch distance A to be set between 4 and 32 mm.
The lock housing is Zinc die cast with a zinc plated finish, while the locating ring is plastic coated black with a textured finish. All other parts are steel zinc plated, with a blue passivated finish. The latches are delivered with the lock enclosed separately.
JW Winco offers an extensive selection of inch and metric size adjustable levers, cabinet U-handles, plastic and steel hinges and locking mechanisms, revolving and retractable handles, hand wheels, hand cranks, tube connection and conveyor components, inch and metric construction tubing, shock absorption mounts, leveling mounts, hand knobs, spring, ball and indexing plungers, jig, fixture and fastening components, retaining magnet assemblies, toggle clamps, metric casters and wheels, universal joints, oil sight glasses, and metric tools for the industrial and commercial equipment industries.
JW Winco
www.jwwinco.com
Filed Under: ALL INDUSTRY NEWS • PROFILES • COMMENTARIES, Fastening + joining • locks • latches • pins
Tagged With: jwwinco
Covered compression latch enhances safety and reduces maintenance errors
Omron D41L hygienic guard locking switch is a tamper-proof solution for ensuring access control and workplace safety
Omron D41G guard lock and handle is an easy-to-wire and intuitive solution for safeguarding machine tools and robotic cells
Omron D41D high-coded non-contact door switch for safeguarding machine tools and robotic cells
