To better meet specific customer needs, JW Winco’s toggle clamp products now include a wide range of new improvements and an expanded selection of accessories.
The standard parts specialist, JW Winco, has optimized its portfolio of toggle clamps in relation to the handling, quality, and assembly — bringing innovative and effective products to the marketplace. New product versions with integrated safety features are also now available.
For example, the toggle clamp GN 820.3 is protected by a safety hook against unintended opening and the associated operating errors. If necessary, the safety locking can be released with a single hand. In the product version GN 810.3, both end positions of the clamp can be secured with this new locking function. This enables the use of longer clamping arms without them closing accidentally.
As a new service, Winco also now delivers the matching spindle assembly with toggle clamp orders. Additionally, if desired, the extended clamp arm is available, making procurement and assembly even easier for the customer.
All Winco toggle clamps are available in steel or stainless steel, manufactured from sheet steel or forged parts, and with galvanized or black-coated surface. Depending on the specific application, customers can choose between vertical clamps with vertically oriented clamping lever, horizontal clamps with horizontal lever, as well as locking clamps and push-rod clamps.
Thanks to the extensive selection and several new developments, such as longer or wider clamp arms, Winco ensures that the ideal clamping product is available to meet each customer’s needs.
JW Winco
www.jwwinco.com
Filed Under: Clamps • locks • latches
