JW Winco, a standard parts specialist, offers a comprehensive portfolio of edge protection profiles for softening and rounding edges, as well as preventing injuries on flaps, doors, access holes, and sheet metal edges of all kinds.
JW Winco’s GN 2181 edge protection seal profile corners, including Type A (above) and Type D (below).
These seals include advanced sealing and protection features. With corresponding contact pressure, they offer protection against splash water, dust, and steam — while reducing noise emissions.
The edge protection seal profiles are made of UL-compliant EPDM or of NBR, and the material NBR is particularly well suited for applications in contact with fuels or lubricants. Depending on the application, the seals can be installed on either cut or bent workpiece edges. The orientation of the seal profile can be selected based on the type and situated on the top or side.
To enable right-angled seal contours without the minimum installation radius that is typically necessary, Winco has expanded its selection with the edge protection seal profile corners GN 2181 with pre-made 90-degree corners. This eliminates the need for manually cutting the profile free. Also, the corner joint is tight and durable thanks to the vulcanization.
The edge protection seal profile corners can be ordered in various leg lengths and shortened as necessary or extended with the corresponding GN 2180 profile. To ensure a consistent seal, the profiles are installed slightly oversized and “compressed.” As a result, the joints are tightly closed and do not require an adhesive.
As a special service, Winco supplies all edge protection seal profile corners even as single parts. This is particularly useful for special solutions or applications requiring only a small number of parts. Winco also produces edge protection seal profile segments on request, such as in a U or Z shape. This means even round or rectangular edge protection seal profile frames (in custom dimensions, vulcanized, and closed off) can be supplied to meet all the needs of customers with regard to the respective size and shape.
JW Winco
jwwinco.com
