Spend less time and costs on cleaning with the latest two standard parts from JW Winco. These new latches GN 1150 are designed to repel dirt and can be cleaned in place. These features translate into increased reliability for production systems.
The GN 1150 cam latches are made of stainless steel with special FDA-compliant seals of EPDM and TPU.
The Hygienic Design (HD) latches support the machine and system cleaning concept known as clean in place, or CIP for short. Even in industries that don’t require compliance with high hygiene standards, the concept CIP (cleaning of components while still fully installed) is becoming ever more common.
Systems, fixtures, and machines can be cleaned quickly and easily, which lowers operating expenses.
This is why JW Winco continuously expands its portfolio of standard parts in HD. GN 1150 are cam latches made of stainless steel with special FDA-compliant seals of EPDM and TPU. The latches have no dead spaces for dirt to collect because of these seals.
When the latch arm is turned 90 degrees, its beveled surfaces produce a tension that reliably presses covers, hatches, doors, or covers against their opposing element (frame or body). The rotational movement is achieved with a simple blue plastic key featuring a socket with two wrench surfaces, which is available as an accessory under the designation GN 1151.
Additional drive types are currently in development. The standard part GN 1150 is available in two versions: The front hygiene version (FH) offers the HD standard on the actuation side, while the inside satisfies the typical requirements. Applications for this part include switch cabinets that must comply with hygiene requirements only on the outside.
The “full hygiene” design (VH) features additional seals for HD quality, even on the latch arm side. Both versions offer protection class IP 66 according to DIN EN 60529, meaning that they protect against the ingress of dust and heavy streams of water from any angle. The seals are also available in other materials upon request, allowing the parts to be adapted to customer-specific media exposures.
Filed Under: Clamps • locks • latches
