KACO launches sealing solution for high-speed applications
By Paul Heney | April 30, 2019
kaco sealsA new era is arising for suppliers of dynamic sealing systems as three main factures will change for e-mobility: higher linear speed, low-viscosity oils containing a high percentage of additives, and bi-directional shaft rotation at the gearbox entrance shaft. Those requirements are relevant wherever electric drives are used like in hybrid or electric cars.
Compared to conventional combustion engines that are used in the automotive market, electric drives have a maximum speed of approximately 15,000 to 20,000 rpm, whereby further increase of speed is expected. KACO high-speed seals have been tested under real-life conditions on our test benches. For tests with a main direction of rotation, the results have been far in excess of customer expectations.
The Chinese norms QC/T 1022-2015 as well as all so-far known customer specifications for bi-directional applications have been passed perfectly. The focus was on real life testing varying the following parameters: oil level (max / min), high and slow speed and standstill period. In addition all durability tests with no preferred direction for rotation have been successful, as the company could find only minimal wear while having very low friction for the application.
“It is very gratifying to know that we made such big progress during the last years with our products used in high-speed transmissions for e-mobility applications. Today we are able to fulfil our customer’s specifications for one- or bi-directional high-speed sealing systems for reductor transmission applications based on robust long-term tests, as our products are tested in accordance to the Chinese norm QC/T 1022-2015 for instance. Our latest patented sealing structures enable our customers to create their e-mobility powertrain purpose-designs for highest linear speeds with alternating input shaft rotation,” said Andreas Genesius, VP Research and Development.
KACO GmbH + Co. KG
kaco.de
Filed Under: Seals • gaskets • O rings, Gears • gearheads • speed reducers
Tagged With: kaco
Paul Heney
