Kaman’s KD-2306, a non-contact linear displacement measuring instrument, features resolution down to 10 nm and speeds to 50 kHz. Features include multiple high-gain output with easy calibration and synchronization.
Based on proven balanced bridge, inductive eddy current technology, Kaman’s KD-2306 makes high-precision static and dynamic measurements, and supports ambient, moderate temperature, and cryogenic-rated sensors. Applications range from lab work to production and process automation. The DIN rail mount packaging makes the system ideal for integration into OEM equipment and industrial control applications.
The KD-2306 can sense both ferrous and non-ferrous metal targets. The RoHS-compliant, CE-marked system includes the electronics, sensor and interconnecting cable. Standard sensing ranges are from 0.02” to 2.4”, with 0.01%FS resolution or better, and non-linearity as little as 0.25%FS. Kaman offers over 30 sensors models including single and dual coil, shielded and unshielded designs.
The KD-2306 includes terminal I/O connections to connect 15-30VDC input power, optional 0-5VDC, 0-10VDC, +/-5VDC, 4-20 mA output, and synchronization cables for multiple channel operation.
Kaman designed-in flexibility and ease-of-use, resulting in both coarse and fine calibration potentiometers, user synchronization without accessing the internals, and multiple output options including single-ended and differential analog DC voltage, and 4-20mA.
A variety of standard options are available to fit the needs of the application including extended length sensor cables, non-standard range/target calibration, temperature compensated calibration, and in-line cable splice. As always, Kaman welcomes customized sensor requirements for KD-2306 applications.
Kaman Precision Products | Measuring
www.kamansensors.com
Filed Under: Aerospace + defense, Sensors (position + other), Test + measurement • test equipment
