Moorpark, CA — Kavlico has developed the P255 general purpose pressure sensor with advanced electronics for enhanced performance. The mixed-signal CMOS ASIC provides for improved EMI/RFI and accuracy specifications. Specifically designed for pressure measurements of 0-15 to 0-1000 PSIA/PSIG, the P255 is a robust device utilizing a ceramic diaphragm that can withstand exposure to a wide array of liquid and gaseous process media.
Excited by 5 Vdc, the P255 provides a linear amplified output of 0.5 to 4.5 Vdc that is proportional to pressure. The sensor has low power consumption, superior long-term stability, and excellent repeatability and hysteresis. Other significant features include over-voltage, reverse polarity, and short circuit protection.
The P255 has a 316 stainless steel housing and has an operating temperature range of -40° to +125°C.
The P255 is RoHS compliant and can be ordered in off-the-shelf designs or adapted to fit unique OEM application-specific requirements. A wide variety of electrical connector and pressure connection ports may be chosen to fit measurement criteria.
Filed Under: Sensors (pressure), TEST & MEASUREMENT
