Kübler by TURCK Expands Encoder Line
By Miles Budimir | April 12, 2010
Kübler by TURCK has expanded its encoder line to include the Sendix® 5006 2-inch incremental encoder, featuring a completely stainless steel housing and Viton® seals to resist corrosion and physical abuse in harsh plant environments. The Sendix 5006 incremental encoder can handle large fluctuations in temperature, from -40 to 85°C, and is IP67 rated when sealed.
Sendix-5006-incremental-encoder
This encoder is available with ten pulse counts up to 5,000 PPR and with push-pull or RS422 outputs. It incorporates a proprietary Safety-Lock™ bearing assembly that has been tested to provide additional protection against vibration and installation errors.
The Sendix 5006 incremental encoder is ideal for use in a wide variety of industries, including food packaging, pharmaceutical, chemical, oil and gas, as well as other challenging applications within corrosive environments or requiring long-term durability.
TURCK
www.turck.us
Filed Under: Packaging, Encoders (rotary) + resolvers, Motion control • motor controls
Tagged With: TURCK
Miles Budimir
