KEB America has introduced EtherNet/IP for its S6 servo drive and F6 VFD products. EtherNet/IP is immediately available with firmware version 2.6 and higher with the application control board. KEB’s implementation uses the AC Drive Profile to increase interoperability between similar device types. KEB’s EtherNet/IP has been tested and is certified by ODVA, Inc.
Supported KEB drives are currently available in both 230 Vac and 460 Vac classes, up to 500 hp. In addition to EtherNet/IP, KEB drives support Profinet, EtherCAT, CAN and Powerlink through a quick parameter adjustment. The KEB EtherNet/IP drive products are available with options like Regenerative Braking, Liquid Cooled heatsinks, Internal Positioning Control, and SIL3 certified Safe Motion functions.
For more information, visit www.kebamerica.com.
