Kepco introduces the model RKE 36-42K, a 36-volt nominal output addition to its 1200-1500 watt, high reliability RKE series.
The output voltage of this model may be adjusted from 25.2V – 55.0V nominal, using the built-in trimmer, and may be programmed remotely via a 0-5.75 volt analog control signal to deliver 6.0V – 55.0V at the output. This feature makes it ideal for battery charging, test, burn-in and margining applications. The RKE series meets all applicable safety and EMC standards, carries the CE mark and is backed by a firm five-year warranty.
Filed Under: Electronics • electrical, Power supplies
