Klippon Connect A-Series Universal Modular Terminal Blocks
By PD&D Staff | December 12, 2017
Weidmuller introduces their Klippon Connect A-Series Universal modular terminal blocks. The Klippon Connect A-Series Universal range includes feed-through, multi-tier distribution, PE, fuse, test disconnect and neutral conductor disconnect terminals blocks. In addition to the new A-Series Universal range, Weidmuller is launching a new A-Series Application range of products designed specifically for use in recurring control panel applications that include voltage/current transformer wiring, control voltage distribution, motor wiring, signal wiring, and initiator/actuator wiring.
The A-Series Universal modular terminal blocks offer increased efficiency and flexibility for control panel application. Key features include:
• Integrated push-button clamp actuator for safer wiring and simple handling;
• Uniform integrated test point for easy continuity and potential/current checks;
• Current identification area on jumpers;
• Spring-loaded mounting foot to compensate for rail size fluctuations;
• Multiple marking areas;
• Two integrated jumpering channels;
• Full range of pluggable terminal configurations
The A-Series Application range offers users custom-fit control panel solutions to help increase productivity for recurring applications. Weidmuller has identified and developed the Application range with product functions that are structured and adapted to specific requirements of panel building. Using the Weidmuller Configurator, a free software download available on the Weidmuller website, users can plan, select and order the exact A-Series Application products needed for their recurring control panel applications.
Filed Under: Rapid prototyping, Terminal blocks
