Klüber Lubrication, a worldwide manufacturer of specialty lubricants, has introduced Klübersynth GE 4 80 W 140, a fully synthetic high-performance gear oil based on polyalphaolefin (PAO) that offers high stability and protection even under shock loads.
With Klübersynth GE 4 80 W 140, Klüber Lubrication adds to its range of oils for railway gears. “Our fully synthetic railway gear oil, Klübersynth GE 4 75 W 90, with a kinematic viscosity of approximately 130 mm²/s at 40 degrees C, has proven to be successful for many years,” explains Thomas Kamprath, rail industry market manager for Klüber Lubrication. “For applications requiring an elevated viscosity, we developed the new railway gear oil Klübersynth GE 4 80 W 140, which shows a kinematic viscosity of approx. 250 mm²/s at 40 degrees C. Its product concept corresponds to that of Klübersynth GE 4 75 W 90, which is approved by many OEMs, but with a higher viscosity.”
Gear oils from Klüber Lubrication can be used in spur, bevel and hypoid gears, particularly if API GL4 or API GL5 is required. Klübersynth GE 4 75 W 90 is approved by several gear manufacturers like IG Watteeuw, Voith Turbo, Siemens-Flende, Stadler Rail, Bombardier, CAF and the German railway operator Deutsche Bahn.
Klüber Lubrication
www.klubersolutions.com
The post Klüber Lubrication introduces synthetic gear oil appeared first on Bearing Tips.
Filed Under: Bearing Tips
