Klüber Lubrication provides solution for lime deposit and water scale removal
By Leslie Langnau | January 9, 2018
Klϋber Lubrication, a worldwide manufacturer of specialty lubricants, introduces Klüberplus Z 01-006 US, a water-based solvent containing wetting agents, corrosion inhibitors and degreasing compounds.
Klüberplus Z 01-006 US can be used to safely remove lime deposits or water scale in commercial and industrial applications such as:
Power plant boilers, piping systems and evaporating equipment
Equipment in refineries, utility companies, paper mills, chemical plants and foundries
Sewage disposal plants, water treating facilities and other municipal water handling operations
This solution is non-corrosive, so it will not adversely affect stainless steel, carbon steel, brass, admiralty metal, copper, iron, lead, PVC plastic, polyethylene, rubber, leather or most metals and/or materials normally found in water-wetted equipment. Additionally, it is non-toxic and non-flammable.
Klüber Lubrication
 www.klueber.com/us/en
Filed Under: Design World articles, Lubricants • oils • industrial grease
Tagged With: kluberlubrication
More on engineering and science
Dan Arvizu: Embracing the soft skills
