Klüber Lubrication, a worldwide manufacturer of specialty lubricants, introduces Klübersynth BZ 68-400, a lubricant specifically designed to mitigate hot bearings in wind turbines.
Hardened residues that accumulate on generator bearings can become a nuisance and prevent efficient operation. Most situations require cleaning by hand, or the wind power turbines must be curtailed which results in costly downtime.
To minimize maintenance and help wind power plants operate at maximum power output, Klübersynth BZ 68-400 frees residues while protecting bearings and providing reliable lubrication against wear and corrosion. As a result of this powerful grease, rolling bearings can be cleaned while in operation.
Klübersynth BZ 68-400 is compatible with several types of base oil, making it a versatile, high-performance solution that can be used beyond wind turbines.
About Klüber Lubrication
Klüber Lubrication is one of the world’s leading manufacturers of specialty lubricants, offering high-end tribological solutions to virtually all industries and markets worldwide. Most products are developed and made to specific customer requirements. During its more than 80 years of existence, Klüber Lubrication has provided high-quality lubricants, thorough consultation and extensive services, which has earned it an excellent reputation in the market. The company holds all common industrial certifications and operates a test bay hardly rivalled in the lubricants industry.
Klüber Lubrication, set up as a retail company for mineral oil products in Munich in 1929, is today part of Freudenberg Chemical Specialities KG, a Business Unit of the Freudenberg Group, Weinheim. Klüber Lubrication has approximately 2,000 employees in more than 30 countries.
Klüber Lubrication
www.klueber.com
Filed Under: Lubrication, Bearings
