The new KNF NMS020 micropump introduces an efficient and reliable solution to transfer, evacuate, or compress air or gases for analytical, medical, and all portable instruments where space is at a premium. This compact vacuum pump measures 17mm (width) x 31mm (height) x 44m (length), weighs 32g, and can deliver high-performance flow rates up to 1.8 LPM, vacuum up to 15 in. Hg, and pressure up to 7.5 psig.
The micropump additionally benefits from a unique diaphragm that promotes high efficiency and flow and helps the pumped medium remain pure and contaminant-free. These micropumps enable safe, oil-free operation without maintenance. Corrosion-resistant wetted parts reinforce their ability to withstand especially harsh conditions. The pumps are powered by cost-effective brush DC motors or brushless DC motors where applications demand extended service life and low EMI/RFI.
All NMS020 micropumps can be tailored to meet particular OEM requirements with a wide range of custom materials, finishes, coatings, and value-added options, including shock and vibration isolation components, restart mechanism against vacuum/pressure, and specialized connections, among others. Pumps are supplied ready for installation and can be mounted in any position.
KNF Neuberger, Inc.
www.knfOEM.com
Filed Under: Pneumatic equipment + components, Pumps
