A global standard parts supplier, WDS Components has launched a range of environmentally friendly hand knobs. Ideal for machinery and OEM use, the new hand knobs are made from a sustainable, biological source — and they’re 100% recyclable.
The new line-up is also highly durable, making these unique knobs an environmentally friendly substitute for standard polymer designs in the majority of use cases. In fact, WDS has duplicated its entire range of glass-reinforced polymer hand knobs in a biopolymer source.
Crucial for industrial use, the company has done extensive research to partner with a supplier that can provide sustainable and recyclable materials that are as durable as a standard polymer design. As a result, the new hand knobs can be used across virtually all of the same applications as standard polymer designs.
The new line-up is well suited to outdoor use and activities in rugged locations. As a result, the environmental hand knobs can be specified for applications such as the adjustment of cameras and optical equipment, through to outdoor machinery. They’re also an ideal replacement for indoor machinery for environmentally conscious organizations.
These hand knobs are created to the DIN6336 star knob design, comprised of a black biopolymer knob grip with a zinc-plated steel shaft. The range is available in thread diameters ranging from M5 up to M12, with both male and female designs.
“The new range of environmental hand knobs has been introduced to fulfil demand for companies with a focus on sustainability,” says Sam Wilkinson, design engineer with WDS Components. “Our challenge was to add a hand knob to the WDS catalogue that is from a biological source that was as durable as a standard polymer, and we’ve achieved that with our new range thanks to a special design that is supported by the right material sourcing.”
As a result of the success of the new product launch, WDS expects to release further standard parts and components constructed from the environmentally friendly biopolymer.
You may also like:
Filed Under: Knobs • handles
