KTR EVOLASTIC highly flexible coupling
By Mike Santora | May 17, 2022
KTR-evolastic-coupling-imageEVOLASTIC is a highly flexible, non-slip, and backlash-free shaft and flange coupling for versatile application in a large number of main and auxiliary drives in mechanical and plant engineering.
The elastomer element prestressed to pressure enables the coupling to reduce torsional vibrations in the drive train and smoothly absorb overload shocks while damping structure-borne noise efficiently. In parallel, it operates in three dimensions (axially, radially, and angularly) compensating for displacements above average.
The basic versions distinguish between directly screwed and plug-in types. They cover all functional mounting conditions ranging from the finished individual element through hub/hub and flange/hub applications to the drive shaft. In addition, the product portfolio allows for highly individual and flexible mounting options tailor-made for the special application.
KTR
www.ktr.com
Filed Under: Coupling Tips
Tagged With: ktr
Ringfeder — Dynamical torsional stiffness: some couplings need finer tuning
PTDA onProduct Information Exchange
PTDA Transmissions: Lessons from the Pandemic past can shape the future
Shaft collars and couplings feature wide choice of standard bores
