    • Subscribe!
Kubler 573T Touch process controller with 2 analog inputs
By Mike Santora | October 8, 2021
z6257-57xT-green-cpd-std-srgb-webTouch process controller with 2 analog inputs
The process control unit with 2 analog inputs can be used in both single-channel and dual-channel operation. For two-channel operation, all arithmetic operations are available to display the sum, difference, ratio, or product. Inputs and outputs are separately scalable.
Can be used as a simple process converter, process control unit (2 point controllers), or for complex measuring tasks in which 2 values are to be monitored, calculated, or further processed in a higher-level control system.
Properties
2 separate freely scalable analog inputs ±10 V and 0/4 to 20 mA, resolution 16 bit.
Tare function, the device can be set to 0 at any input voltage.
Programmable linearization With up to 24 support points, input via keyboard or by means of the teach function.
Mean value measurement programmable from 2 to 16 measuring cycles, with strongly fluctuating input signals.
Simple programming by entering the desired display value for a defined input signal.
Fast measuring rate of 25 ms per channel alternating.
RS232 or RS485 serial interface for reading and writing data.
Benefits
Up to 3 display values in one device, display A, display B, calculated display from A and B.
AC and DC supply voltage in one device.
Simple plain text programming via touch display and separate tare or teach function.
Can be used as a simple process converter, process control unit (2 point controllers) or for complex measuring tasks in which 2 values are to be monitored, calculated or further processed in a higher-level control system.
Mathematical linking of the measured values of input A and B. The result can also be multiplied, divided or added to an offset value to obtain the desired display value.
Analog output 0/4 to 20 mA, or ±10 V.
4 fast PNP switching outputs, 50 ms, with switching hysteresis, step or drag preset.
Programmable display update.
Kubler
www.kuebler.com/en
Filed Under: Controls (not motion controls)
Micro Controllers and Design Software optimize smart machine design
Watlow’s POWERSAFE medium voltage thermal system
ReeR MOSAIC safety controller components
CLICK PLUS serial communication option slot module and 2-slot CPUs
    • Subscribe!
