The draw-wire encoder C105 features a compact design. It is available with various wire types. All encoders with 58 mm synchro flange and 6 mm shaft, as well as analog sensors with redundant interfaces can be combined with this draw-wire mechanism. The cable and connector orientations of the encoder can easily be adapted to the position of the mechanism. A flexible wire outlet compensates mounting tolerances.
Flexible and compact
Encoder replacement and connection technology adaptation possible by the user.
Measuring lengths from 3 to 6 m.
Simple adaptation of the position for the connection technology.
Flexible wire outlet and different wire types.
Compact design.
Simple installation.
Scalable analog output with limit switch function.
Redundant sensors.
Kubler
www.kuebler.com/en
Filed Under: Product Design & Development
