Kubler IN81 1-dimensional inclinometer
By Mike Santora | December 8, 2021
The IN81 inclinometer is used for the acquisition of a tilt angle in the measuring range from 0 to 360°. Due to its high robustness and protection up to IP69k, as well as its wide temperature range from -40 °C to +85 °C, it is excellent for, among other uses, outdoor use in mobile automation.
Kubler-inclinometer-tech-specs
Robust
High IP67 and IP69k protection in one device.
Highest resistance due to metal housing.
Stable accuracy over the entire temperature range from -40 °C to +85 °C.
No long-term drift thanks to sensor array technology.
z3287-IN81-1dim-2con-inl-std-srgb-webVersatile
Preset and Teach functions.
Measuring direction 1- or 2-dimensional.
With switching outputs.
Stack mounting for redundancy possible.
Kubler
www.kuebler.com/en
Filed Under: Automation components
Tagged With: kubler
EXAIR.com Improves Web Accessibility with ADA Compliance Features
Custom air knives from EXAIR for unique applications
Aerotech introduces two-axis laser scan head
SureFrame cut-to-length T-slotted rails
