Kubler MWE02: Capture linear movements rotationally
By Mike Santora | December 9, 2021
Kubler-MWE02The MWE02 measuring wheel system is the ideal solution for reliable speed, position, and distance measurement in applications with linear movements. These are recorded rotationally via the measuring wheel with attached encoder and converted into measurement data.
An integrated spring ensures the contact pressure of the measuring wheel on the measuring surface required for reliable measured value acquisition. Due to its compact design, the system is also suitable for the tightest installation spaces and can be installed quickly and easily horizontally, vertically, or overhead.
Features
  • Compact measuring system with flexible mounting options: vertical, horizontal, or overhead. The encoder can be mounted on both sides in 30° steps on the encoder spring arm.
  • Integrated spring for optimum contact pressure of the measuring wheel on the measuring surface and as compensation for unevenness.
  • Robust incremental Sendix encoder with max. resolution up to 2500 pulses/revolution and max. speed up to 4500 min-1.
  • Measuring wheels for different measuring surfaces: Available with O-ring NBR70, smooth plastic (polyurethane) or cross knurled (aluminum) coating in 200 mm and 6“ circumferences.
  • Integrated mechanical spring travel limitation.
Benefits
  • Simple and fast mounting even for the tightest installation spaces.
  • Direct and reliable measurement on the measuring surface for precise speed, position, and distance measurement.
  • Accurate measurement values for efficient production operation.
  • Matching measuring wheels for any measuring surface.
  • Spring overload protection ensures long service life.
Kubler
www.kuebler.com/en
Filed Under: Encoders (rotary) + resolvers
Tagged With: kubler
POSITAL’s explosion-proof rotary encoders receive ATEX/IECEx certification
z4636-F5858-Profinet-enc-std-srgb-web
New generation industrial ethernet encoders from Kubler
Sendix M3658 encoder with IO-Link interface
Kubler- A41-product-shot
Kubler A41 draw-wire mechanism with encoder
