Slip rings for robotics / End-of-Arm-Tooling
The pancake slip rings are the ideal solution for End-of-Arm-Tooling in robotics. They guarantee the reliable transmission of signals, data and load in a very short installation space and at low weight. The system consists of two superimposed boards with slip ring tracks and transfer brushes. The flexible design allows optimal integration into your End-of-Arm-Tooling. For example, for additional positioning on high-precision robots, the slip ring can also be combined with a secondary encoder.
Properties
- Up to 20 channels for fieldbus / Industrial Ethernet, load and signal transmission
- Particularly short design, low weight with high signal density
- High contact reliability
- Optionally with integrated Kübler absolute encoder
- As kit or encapsulated for optimum integration
- Maintenance-free
Your benefits
- Diameter 160 mm – installation depths starting at 10 mm
- Working temperature from -40°C … +75°C
- Load transmission up to 5 A / 60 VAC, 48 VDC
Kubler
www.kuebler.com/en
Filed Under: Slip rings + rotary unions
