The DX6 CrossOver Vise features strategically located holes for through the body mounting to achieve closer positioning of multiple vises with no need for space consuming toe clamps. The vise also uses sine keys which can be inserted quickly into pre-drilled dowel holes in the vise base for positioning onto t-slots, machine tables, grid plates, sub-plates, fixture plates and tombstones.
DX6 CrossOver Vise comes standard with a Groove Lock jaw plate and Groove Lock workstop for accurate part locating within the clamping area. The workstop uses a single bolt design for adjusting and slides across the full length of the jaw to accommodate for a variety of parts sizes and does not interfere with the part or spindle.
To eliminate chip build-up the DX6 CrossOver Vise has convenient evacuation slots located in the sides and ends the vise body. Easy chip evacuation is critical especially in heavy production and hogging operations which tend to create mass amount of chips and causes inaccurate workpiece positioning and clamping.
For vise setup, Kurt has incorporated a recessed pocket located in the movable jaw for easier lifting and positioning. Now a machinist can easily grab a hold of the 65lbs vise from both ends for lifting and position onto the machine table.
The DX6 CrossOver vise achieves highest levels in workholding strength and performance where flatness and parallelism are critical to precision machined components. By combining design features from the Kurt AngLock and Kurt Pull-Type designs, and designing a new 4-bolt stationary jaw, the DX6 reduces jaw deflection, reduces stress in the body to maintain flatness after assembly, and creates all-directional clamping alignment.
Additional DX6 CrossOver®vise features include: 80,000 psi ductile iron body, nut and movable jaw, a semi-hard steel screw and a hardened vise bed and jaw plates. With enlarged holding capacity, the DX6 CrossOver vise features a full 9-inch jaw opening within the inside jaw position. A lighter and narrower vise body with a footprint of 7.391” wide x 16.810” long allows more vises on the machine table. DX6 is interchangeable with Kurt’s popular D688 vise.
Kurt Manufacturing Co.
www.kurtworkholding.com
Filed Under: MOTION CONTROL
