L-com Debuts 4G/LTE Mobile booster kit
By Paul Dvorak | July 25, 2016
L-com Global Connectivity, a preferred manufacturer of wired and wireless connectivity products, announced today that it has released a 4G/LTE mobile booster kit.
how it works 1.The outside mounted omni-directional antenna captures voice and data signals from the cell towers and transfers it to the cell booster 2. The cell booster receives the signal, amplifies it and rebroadcasts it via the inside mounted antenna 3. Your cellular mobile devices get a better signal which in turn reduces dropped calls and slow data speed The HAKIT-72150-M01 booster kit lets you simultaneously connect multiple mobile devices and works with 2G, 3G and 4G networks in the US. It is designed to read bands from 700 MHz to 2100 MHz. LEDs on the front panel indicate the condition of the booster and alert the user of any possible issues. The HAKIT-72150-M01 is designed for in-vehicle use only. It can be installed into cars, RVs, trucks, public transportation vehicles as well as boats.
How the booster kit works
1. The outside mounted omni-directional antenna captures voice and data signals from the cell towers and transfers it to the cell booster
3. Your cellular mobile devices get a better signal which in turn reduces dropped calls and slow data speed.
The unit is designed for in-vehicle use only. It can be installed into cars, RVs, trucks, public transportation vehicles as well as boats
L-com’s HAKIT-72150-M01 4G/LTE mobile booster kit is an ideal solution to meet today’s ever-increasing need for consistent cellular connectivity for mobile devices. It can be difficult to obtain a reliable cellular signal while in a car, RV or boat. This booster captures weak cellular signals and transfers them to a cell booster. The cell booster then amplifies and rebroadcasts the signals inside the vehicle, improving call quality and increasing data speeds while reducing the frequency of dropped calls.
“Weak signal areas as well as physical obstructions inside a vehicle can affect the performance of cellular devices.  When installed in a vehicle, our new 4G/LTE mobile booster kit helps improve cellular voice and data signals so users can enjoy crystal-clear calls and fast, consistent data speeds,” said Ken Burgner, Product Manager.
The HAKIT-72150-M01 mobile booster kit mounts inside almost any vehicle and can be especially useful for commercial vehicles used for utility, construction, public safety (fire and police) and transportation (taxi, bus, etc.). Designed for in-vehicle use only, it is powered by a 12V power adapter which is included. This mobile booster kit allows you to simultaneously connect multiple mobile devices and works with 2G, 3G and 4G networks on most US carriers. The boosted cellular signal also helps reduce radiation and increase battery life for up to 2 hours of additional talk time in weak-signal areas.
Filed Under: Renewable energy
Tagged With: lcom
Solar Atmospheres partners with energy storage company
Material simulation, testing improve lifespan of offshore wind turbines
TEGAM announces the ultimate handheld meter – the Display Probe
Harting presents new wind solutions at HUSUM Wind
