L-com Global Connectivity announced that it has developed a line of right-angle USB 3.0 cable assemblies.
L-com’s right-angle USB 3.0 cable assemblies are specifically designed for high-speed data applications in tight spaces. They also support high-resolution cameras used in USB3 Vision applications. Capable of 4.8 Gbps, these cables are ten times faster than L-com’s USB 2.0 angled cables.
“There is a need for cables that can maneuver the constrictions associated with smaller devices and tighter, enclosed spaces. USB 3.0 connectors are the same size or larger than their 2.0 equivalents; as such, space is at even more of a premium. Our right-angle USB 3.0 cable assemblies are the perfect solution for high-speed data applications in confined spaces,” said Steve Smith, Product Manager.
L-com’s right-angle USB 3.0 cable assemblies are available in six stock lengths with up or down exits and Type A, B, and Micro-B connector configurations. They feature molded connectors with 30-micro-inch gold-plated contacts and are fully shielded to provide protection against EMI/RFI.
www.L-com.com
The post L-com Launches Right-Angle USB 3.0 Cable Assemblies appeared first on Wire and Cable Tips.
Filed Under: Cables + cable management, Wire & Cable Tips
