Lenze Americas recently launched the modular L-force I/O-System 1000, which incorporates intelligent electronics and an innovative mechanical concept to deliver a higher degree of value and machine automation functionality.
The slim-line Lenze I/O-System 1000 features a highly deterministic method of controlling input and output modules and the ability to read touch probe inputs required for synchronized movements in cyclic production processes. A minimal internal cycle time and a time stamp ensure the I/O-System 1000 is suitable for real-time-based architectures and can meet the most stringent automation speed requirements.
Lenze I/O-System 1000 modules allow eight connection points in 12.5 mm of space on a conventional DIN rail. A clearly structured labeling and diagnostics concept includes easily identifiable status LEDs with a single labeling field uniquely assigned to each LED. An I/O 1000 station can be assembled completely without tools, with up to 64 modules configured to form a station using the integrated backplane bus. Digital output modules include a module with two integrated relays (DC 30 V / AC 230 V, 5 A). The product range includes function modules for connecting thermal resistors and thermocouples, a range of counter modules, and a module for evaluating encoders with an SSI interface.
Plug-and-play electronic modules eliminate the need for field wiring and simplify module replacement. Tension spring terminals and the block diagram on the housing help prevent mismating and facilitate a secure connection during installation and maintenance.
Lenze Americas
http://www.lenzeamericas.com/
Filed Under: Factory automation, I/O modules, Motion control • motor controls
