Laird’s supercool thermoelectric assembly increases cooling performance by up to 60%
By Jillian Zavoda | August 2, 2018
Laird has launched a high performance thermoelectric assembly (TEA) series for indoor lab environments that offers a higher cooling performance per unit volume than competing systems. The SuperCool Series TEA features a unique hot side air heat sink design that dissipates heat more efficiently than competing heat exchanger technologies. Utilizing optimized thermoelectric modules (TEMs) in combination with a high performance heat sink and fan shroud assembly, the SuperCool TEAs transfers heat to air more rapidly. The SuperCool Series is designed for precise temperature control in compact analytical storage compartments and medical diagnostic chambers where space is a premium.
The SuperCool Series contains three models to provide engineers with heat transfer mechanism options on the control side. Heat can be absorbed via liquid, conduction or convection. The Liquid to Air unit has a cooling capacity of 202 Watts, while the Direct to Air has 193 Watts and the Air to Air has 166 Watts. All cooling capacities were measured at ?T=0°C (Delta T = 0 degree C) with a nominal operating voltage of 24 VDC. Custom configurations are available upon request.
“This is a major breakthrough for thermoelectric assembly technology to offer such high heat pumping capacity in a small form factor. The SuperCool Series enhances the cooling performance by up to 60% in same form factor versus conventional thermoelectric assemblies,” said Anders Kottenauer, Senior Vice President of Laird’s Thermal Systems business. “Our customers in the medical and analytical markets are demanding more stringent thermal requirements with less available space to work with. We have extensive design expertise, a diverse product portfolio, and a global footprint, which matches up well for our customers’ requirements.”
Laird Thermal Systems
https://www.lairdtech.com/
Filed Under: Appliance engineering + home automation, Power Electronic Tips, Fans
Tagged With: lairdthermalsystems
New seals and materials launched for aerospace industry
FoldiMate equity crowdfunding campaign to support laundry folding robot appliance
Heavy-duty HEPA vacuum from EXAIR for 30-gallon drums
Motion Trends: New motor breeds are smart, connected, and compact
