Lambda AC-DC 300W Series Power Supplies
By Design World Staff | March 22, 2007
Lambda has expanded its popular NV family of configurable AC-DC power supplies, adding a product series that supplies 300W. The new NV-300 series is especially suitable for use in high-density medical, data communications, and test-and-measurement equipment.
Units measure a compact 3.75 x 7.25 x 1.34 in., making them compatible with 1U enclosures. They can provide up to four regulated outputs, with a 5- or 12-V standby output optional. Output voltages are currently available from 1.8 to 24V, with currents to 40 amps. No minimum load current is required on any output. Input voltage ranges from 90 to 265 Vac, 45-63 Hz with active power factor correction.
The new series meets EN55022 Level B conducted emissions standards with an earth leakage current of 257 microamps, assisted by a patent-pending noise-canceling transformer. Additionally, the supplies have IEC/UL/EN60601-1 medical approvals, as well as IEC/EN61010-1 and IEC/UL/EN60950-1 approvals, and carry the CE mark.
Lambda NV-300 series power supplies are available now, priced at $239 each in 100-unit quantities for a four-output configuration.
For more information, visit: www.lambdapower.com.
About Lambda
For more than 50 years, Lambda Americas has been a leading provider of power supply solutions. The company’s broad range of products provides power for industrial, telecommunications, data communications, medical, and test-and-measurement applications worldwide. Lambda is a unit of TDK Corporation, a leading global electronics company and is headquartered in Tokyo.
Tel: 800-LAMBDA4 (toll free) or
619-575-4400
Fax: 619-429-1011
Filed Under: Appliance engineering + home automation, Semiconductor manufacture, Wireless • 5G and more, Medical-device manufacture, Power supplies
