Standard EPIC HBE Kits
Kit includes all components needed to make electrical connection. Inserts are screw terminated with wire protection. Rated current 16 amp. Screw termination wire gauge range 20 to 14 AWG. Hoods and bases standard grey. Meets IP65, NEMA 4 and NEMA 12.
Epic Ultra kits
These kits also include all components needed to make electrical connections. Inserts are screw terminated with wire protection and rated for a current 16 Amps. Screw termination wire gauge range 20 to 14 AWG. Housing and base material is a corrosion-resistant, nickel-plated die cast zinc, while latches and bolts are stainless steel. An integral stain relief accommodates cable diameter range of 6 to 21 mm depending on housing style. 360° copper EMC brush within strain relief virtually eliminates EMF. Meets IP65, NEMA 4, NEMA 4X, NEMA 12.
Technical data
Temperature range | -40 to 100°C |
Voltage: | 600V |
Current: | 16 Amp/Contact |
Wire Size: | 20 to 14 AWG |
Epic Ultra for harsh environments
Kit includes all components needed to make electrical connection, as well. Inserts have vibration resistant cage-clamp termination. Rated current 16 amp. Wire range: 20 to 14 AWG. Hoods and bases standard gray. Meets IP65, NEMA 4, NEMA 12.
Filed Under: Green engineering • renewable energy • sustainability, Connectors (electrical) • crimp technologies
